Aabeck,
thank you for pointing that out.
I must have missed that post.
the instructions are much clearer since I read them.
rnstns,
lets try this.
as pointed out earlier by willxfmr, write down your instructions.
but let's do the plc code this way.
what is involved at section 1?
write the code for this section and see if it works.
reset the code.
now, what is involved in section 2, forget section 1 and 3, just do section 2.
write that code.
now then, what does it take for section 1 to feed section 2?
when you make that work, move to section 3.
in all your projects, read the specs, write them down, and break the project down into sections. things will be much easier.
everyone here is willing to help you under one condition., you put forth some effort and show what you have done.
james
