Change value on SCL instruction
bendanator
Dec 2018
convington
27
Hello Everyone ,
I am trying to change the value for a SCL instruction for the in raw max but the instruction has greyed it out and doesn’t allow for changes to be made. I’s there a trick to allowing myself access to these values?
Thanks,
please tell us what model the plc is and what software you are using.
are you online with the plc?
is the plc in rum mode or remote program mode?
can you make online modifications?
lots of questions.
james
Using Rslogix 5000
Controller 1769-L33ER CompactLogix
Revision 28.012
I was offline and tried to make the change and download. The is in Function block Diagram as while. When I open the function block for the SCL and all the scaling values are Geryed out and won’t allow me to change.same is if I go to edit tag.
Any information will help I’m sitting at work till I figure it out.
Does your license include function block? Standard license won't allow function block editing, you can view but not edit.
in most cases, values which are "wired" to an instruction's "pins" will overwrite any values that you type into the internal parameters ...
It's a while since I had used this that I forget where the setting to enable/disable object security is. There are some devices (pumps/valves)...
837
Hi all. I am looking at a valve position which has been scaled for an operator HMI. The valve position is in 0-100% shown to the operator for...
1,113
Hello, I am currently trying to control a motor in my plc. I've made a simple on/off button logic. And it works pretty well, when i press the...
25
5,900
Hello all, wondering if there's a simple way to detect when a tag's value has changed. I have some tags whose values get updated every so often...
1,634
Hello guys hope y’all healthy during this time, Im looking for help in a project im trying to finish. I need to get a bool (ote) when a dint...
1,695
