AB 1738-AENTR to Omron PLC eip communication
jsvendor
Feb 2018
Macomb Michigan
I am trying to communicate to a AB 1738-AENTR on a OMRON ethernet/ip network. I have configured the AENTR module through the web browser and have been using Omron's Network Configuration tool to set up the network. I
can see the AENTR but cant seem to communicate to it. I think this has something to do with the input and output byte size? Does anyone out there have any experience in setting up a 1738-AENTR in a OMRON system? If so, how do I determine what the proper byte size is? Also, is there something else I should be doing to get the module working?
Sorry I don't have any advice but that would be a fairly unusual arrangement around here.
I need to add 1738-AENTR ArmorPoint Ethernet module to Logix5000 system. I have 1756-A13 backplane with 1756-L63 Controller and 1756-ENET/A...
1,772
We had recently upgraded Rockwell control system from ControlNet to Ethernet (1719-AENTR). and in last couple of months 2 different AENTR devices...
178
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
343
Hello all. I have a remote that uses a 1734-AENTR series C. We had to change it to a new one and, after adjusting the IP and number of slots...
534
The issue we have is that the IT2I thermocouple card and the RTD temperature sensor card connected through a point IO AENTR is constantly trying...
520
