Any way to make an AND gate in RSlogix?
opmal7
Dec 2014
Moline
35
This might be the wrong terminology, but basically I have 3 values I want to compare, 2 integers from the PLC and a known value (0). So, if N1:0 AND N1:1 are both 0, I don't want the rung to execute. Either one of them can be 0, so long as they are not both 0. There's probably an easy way to do this, but I'm struggling to find the right instruction.
I want to allow values of <0, >0, and 0 in either of the variables (not both).
The only condition that should not allow rung continuity is if N1:0 and N1:1 are both 0.
Yes. Should have specified GT rather than GEQ compare. I think that there is also an EQ compare function available.
Maybe I'm missing something, but I'm not following the logic.
If I use 2 GT, or EQ instructions I don't see how that accomplishes the goal. If I use the GT instructions, it doesn't allow for any negative numbers, which I want to allow.
If I used 2 EQ in series, if either one is 0, the rung won't execute.
N1:0 NEQ 0 OR N1:1 NEQ 0 (in parallel branches) would work at the beginning of the rung. If both are 0, the rung won't execute, but if one of them is anything other than zero, negative or positive, the rung will execute.
I think that should do it. Thanks for the tip!
how can i use my allen Bradley RSlogix PLC to gate triggering to a TRIAC or thyristor actually i want to gate triggering to the TRIAC or...
6,257
I've been using RSLogix 5000 for some time and have always used the "BNOT" block to inverse a digital signal in FBDs. This can take up a lot of...
2,262
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
84
Hello, I have problem i'm working on boiler plc, but i get to the problem that i can't solve myself. I have problem with material gate. I need to...
351
Hi all, Another (hopefully basic) Wonderware question. Once again, I have a template called, say, $Tank. $Tank has an attribute Number...
809
