Simatic CFC won't take new adresses from symbol table
Weo
Feb 2006
Sweden
82
I have a running project that will now be duplicated with some changes. Theres been lots of changes of in and output adresses in symbol table. The project is set to symbolic adressing under the block folder properties. All blocks was nicely taking the change of adresses that I did in symbol table.
But for the part done in CFC its not working as smooth.
After I compile I get the errors for connections to in and outputs being changed in symbol table, as read there is a function under "Options - >Syncronize with symbol table". As I understand you are meant to used this function when you done changes in symbol table as in my case? Anyone with experience?
Anyway, this does not work and after recompiling all errors are still there.
I hope that there is a nice way to do this manoeveur in a few clicks?
I can go to each separate error and simply click on the connection to adress, and that will open the symbol table and in MOST cases update with the correct physical adress after I click on the symbolic name.
In some cases it does not even take the new correct adress, even if it finds it. When I click it the old adress is still there.
Someone with a little more experience in CFC has surely seen this before. What is the trick ? :)
Many thanks in advance
SW used: Simatic Manager v5.5 SP5 + CFC 8.0 SP4
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
81
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
164
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
300
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
316
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
149
