fishin_fl
I am trying to trigger an output twice after a duration of time. The operator has to trigger a laser from the HMI. This fires the coil. Which works. I need to wait 1 second then fire again without the operator having to touch the HMI.
The reason for the second fire is to shift the array inside the laser to push the next measurement to the input of the PLC.
right now the operator has to tap the pushbutton on HMI then wait and push again.
How would I do this? I know you can not put 2 rungs with the coil because it will cancel each other out.
These are my two lines on Compact Logix.
XIO Line_Start_Latch XIC Screen_Trigger_1 OTE Trigger_1 MOV PadDia_inches_1 Hd2_PadDia_Begnining MOV Hd2_PadDia_Begnining PadDia_screen
BST XIC Trigger_1 NXB XIC Trigger_2 BND OTE Laser_Trigger_1
