as Peter said,
sticking air cylinders, valves, water in the compressed air, and even certain types of compressor oil will play a big factor in the application.
ALL air cylinders have different levels of friction in the seals and require different amounts of air to get them moving. the only way around this issue is to pay a fee to the factory to test each cylinder and send you closely matched cylinders. but when one goes bad, you're back to square 1.
if the system is critical, put a frl and then a 5 micron coealescent filter in front of the quick dump exhaust feeding the system.
the 5 micron filter will need to be monitored frequently to remove the trapped material.
james
