cdwilliams496
First off, let me say thanks to anyone and everyone for reading this post and helping if you can.
Currently, I am in the process of reducing 10 identical SLC plcs and HMI systems down to just one Control Logix PLC processor connected to the 10 HMIs.. Since in the past all the SLC PLCs were independent of each other, the tag names and addresses were the same from system to system. Now since I am using one processor, I am putting each system in its own local program within the PLC and using so that I can continue to use the identical tag names for troubleshooting purposes between machines. I have completed the updated Logix program but I am having issues with how to have the right HMI pull tags from the correct local table in the PLC.
Example in Factory Talk View Studio:
Address: ::[Conveyor]Program:Conveyor_1.B3[6].2
_2
_3 etc.....
What can be done so that to put in place of the 1,2,3 etc
I have built an screen on the HMI were you use an 'Numeric Input Keypad' to choose between 1 -10 as a tag name of "System_Number" to pick which conveyor system this HMI is attached.
But when I try to use: ::[Conveyor]Program:Conveyor_{System_Number}.B3[6].2
I am not getting it to work correctly......
Any information and/or suggestions will be greatly appreciated!!!
_2
_3 etc.....
