FactoryTalk View SE - Add Alarm
reykam
Sep 2015
Monterrey
Hello everybody :rolleyes:
I have a doubt, I have a project with FactoryTalk View SE v6.10 and I need add some alarms, but currently is working and keeps records alarms of several PLC, but I can´t see the currently Alarm server for to work with it, the question is, where are saved the currently alarms?. What is the path to save alarms? or if I add other Server Alarm, I´ll create a conflict with the alarms that are working?
thanks so much
What version of alarms are you using? The Old tag alarms or FTA&E Alarming?
This is important. I added an alarm for a client the other day. they had them setup both ways. but the screens used the tag based alarming. this may be because it was imported from an REVIEW project I'm. not sure
Thanks for your help
Really, I am not sure what kind or method was used to add alarms because I have only a backup of HMI server, and I am not familiarized with FTV SE but I know that I need to see a Alarm Server to add the alarms (FTA&E) and my doubt is because I can´t see a Alarm Server in the backup.
The section of display have a banner to alarms. I supposse that project have a Alarm Server(I can´t see). If I add other Alarm Server may be cause conflict? or may be not display alarm in the same banner.
Well, the next monday I´ll work with this Server and I know that you need more information for help me, I am thankful with you.
gclshortt thanks for your pdf
rdrast and DwSoFt thanks for your experiences
Hello, When I click on the processor in Communications Setup, it says to select a different path...it can't be used. It gives no explanation as...
3,403
Hello! I need to create a shift report based on SQL data logging. To do this I tried to use MS FlexGrid OCX but got an error message about missing...
3,849
Hello All, I need to add a SLC500 to FTView Studio and have run into a roadblock. The OPC topic is configured in RSlinx without a problem, but...
3,904
Hi, guys, how r u? I imported a .JPG picture from a computer to image section in FactoryTalk View. But how to add it to the screen...
3,049
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
117
