L1 vs. L55
Allen Nelson
Apr 2002
West Chester, PA
1,368
I've tried looking through the literature.
What are the differences (besides price, and assuming comperable memory upgrades) between the ControlLogix 1756-L1 processor, and the ControlLogix 1756-L55 processor?
Is the L1 being made obsolete by Rockwell? What's the deal there?
And if I missed it, where can I find the comparison chart? It doesn't seem to be at http://literature.rockwellautomation.com
Looks like there is a significant jump in "standard" memory. The L1 has 160K base (though it is expandable), while the L55 seems to start with ".5 MB Expansion memory".
I haven't used these myself, so I don't know if anything in the architecture changed to use/eliminate the base memory and/or speed up access to the expansion memory.
Not much info, but look here .
Marc
L55 vs. L6x
Thanks for the quick reply. :site:
If anyone wants to compare the ControlLogix 1756-L6x and the others, it would be a goodness (again, ignoring price and assuming comparable memory).
The real question is: When do you select one over another?
A-B is not making and selling L1(Logix5550) processors for 3 or 4 years already.
They just can't get ICs and memory anymore.
Ver 13 of ControlLogix is the last version to support L1 processors as well as Flexlogix L33.
L55(Logix5555) will be in production for a few more years, but if you are working on the new project definately look L6x series.
I was told that new L6x processors (series B) coming out very soon.
We just bought an L62 with 4MB memory for a little less than I could get an L55M14 with 3.5 MB memory.
With support for compact flash cards, I thought the choice was easy.
The only upside to the L55's I can think of is the memory expansion.
They are supposed to be much faster too.
By the way, I also had no idea what the difference between L1's and L55's was.
RSL :)
As of today it makes no sence to buy L55 processors, as well as L1 which is no avalable anyway.
L6x can do all L55 can do.
As menitoned above for less money you would be paying for L55 you will get with L6x:
- more stable processor
- same or larger RAM memory
- much faster logic execution
- 64MB compact flash were you can dynamically save your data
The only drawback: L6x uses battery faster than L55
Agreed. The battery module (1756-BATM) is a must with these processors.
New L6x Ser B will not have this problem - it will use battery during shutdown process only while saving data to CF.
It will be using new battery also
Was just about to ask about why the battery drain on the whole family of these proc. I still don't understand why with all the non-volitile memory around why do those proc even need a battery let alone a monster (1756-BATM).
Drewcrew6
For L55 processors it is very costly to have EEPROM option.
CF card for L6x is much cheaper solution,
Keep in mind that every time you restore from CF or EEPROM, all data tables will be restored to the original values.
Also in order to write your on-line program changes to CF you have to put processor in Program Mode - it is not always possible.
L6x series B should partially relove this issue - will see how it goes.
The L55 is newer and a little bit faster than a L1. The memory size of a L55 is fix, a L1 was designed do replace the memory card by the user. There's a overview regarding the scantime of the instructions between the L1 and the L55. If you're interested in this, I can have a look for this. The 6x is the newest generation of processors. It's faster than the L55, especially for motion instructions. You need a newer Firmware/Software to handle this, for the 63 version 12 is ok, but for the 61 and 62 you need 13. The L55 is running with version 7 (?) and newer.
If you have a new project you should select the 6x family.
Hi, I want to exchange data between two L55 PLCs using ENBT PLC1 is the main PLC and consist of 1756- CNB, L55 CPU and ENBT. Five remote I/O racks...
1,028
Im new to Ethernet/IP so I expected some issues but I am not sure if what I am trying to do is even possible. I believe these 2 PLCs should be...
1,755
I feel a little silly asking this, but can you “hot swap” a battery on a 1756-L55 processor?
1,234
Hi, Anyone can help to get the FW16 for 1756-L55 as the CPU OK indication is flashing red as I have a new CPU and inserted a memory module. While...
1,707
Hi, I just bought a new control logix 1756-L55 from a supplier in UK. The Red indication is showing stable and as per the manual its showing CPU...
1,825
