plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old September 14th, 2023, 09:01 AM   #16
Mas01
United Kingdom
Mas01 is offline
Edit: Could it be firewall issue? But that wouldn't make sense to me, because how else would I be able to compile code etc?
Edit: I can ping the IP address and that's fine too.
Old September 14th, 2023, 09:34 AM   #17
Puddle
United Kingdom
Puddle is offline
On your device configuration check the following settings under profinet interface:
-Ethernet addresses: Tick the box for "use router" and put in the router IP
-Web server access: Tick the box to enable web server
I seem to remember having an issue with accessing the web server without the router IP setting.
Old September 14th, 2023, 09:52 AM   #18
Mas01
United Kingdom
Mas01 is offline
This first one in bold...on mine it was UNticked, so I ticked it. It auto-filled with 192.168.0.1, appeared in pink suggesting it was a bad value, for some reason (?)
The second one was already ticked.
Did a save, went back online, but still can't see the webpage when I enter https://192.168.0.1.
Many thanks for trying to help me. Appreciate it.
Cheers
Old September 14th, 2023, 10:11 AM   #19
Mas01
United Kingdom
Mas01 is offline
EDIT: The only "router" in my system (if router is the right word for it) is a SCALANCE XB005 ...thus far, I've only ever called it a "switch". It connects to the PLC, HMI, and development Laptop.
Would this SCALANCE box have its own IP?
Old September 14th, 2023, 10:15 AM   #20
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
I've accessed the web page without the router option being ticked. When you download web page related stuff, there is an extra check box you need to tick for the web applications - I've not got a real plc to test this but I'm sure a tick box is shown when downloading to a real plc.
Edit: I might be confusing the check box requirement, and that you need to check it when you have a ViewOfThings application.
__________________
S7-300 to 1500 conversions done - email (minus the spam) to spams7conversions@hotmail.com
Old September 14th, 2023, 10:35 AM   #21
mk42
United States
mk42 is offline
that scalance box is unmanaged, which means it has no IP.
A router bridges two different subnets and lets traffic move between them. From the automation layer this seems super trivial, but from a traditional networking perspective it's apparently a big deal.
What is the IP of your laptop you're using to try to access the webpage? If it's in the 192.168.0.X subnet, you don't need a router.
Make sure you're using the https:// before the IP. http:// is disallowed according to your settings (the default).
Old September 14th, 2023, 10:58 AM   #22
Mas01
United Kingdom
Mas01 is offline
I'm not sure what the IP address of the development laptop is.
Here's what I get went I type "ipconfig" at the command prompt (see pic).
Would one of these be the IP of the laptop?
Old September 14th, 2023, 12:03 PM   #23
Mas01
United Kingdom
Mas01 is offline
I think the expression is "Clutching at straws" LOL
Do I need to set this up, by any chance?
Old September 14th, 2023, 12:16 PM   #24
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
It is not the user-defined pages.
With the webserver enabled and a user configured you should be able to open a standard webpage.
It could be your PC or the webbrowser.
Try another PC, try chrome, firefox.
__________________
Jesper
NOTICE:
JesperMP has passive-aggressive tendencies, can be impolite and may even use sarcasm !
Also: ᛁᚠ ᚢᚬᚢ ᚴᚬᚾ ᚱᛅᚬᛏ ᚦᛁᛋ ᚦᛅᚾ ᚢᚬᚢ ᚼᚬᚠᛅ ᚴᚬᛁᚾᛅᛏ ᛘᚢ ᚱᛅᛋᛒᛅᚴᛏ
Old September 14th, 2023, 12:27 PM   #25
Puddle
United Kingdom
Puddle is offline
I think I gave bad advice there by assuming (incorrectly!) that you were connected to a wider network. The value for router address is the default gateway from the command prompt.
User defined pages is for things like HTML pages, I have a few configured to show tables of information to allow people to see relevant data.
Sounds like it should be working. You could try unticking the https box in case the browser is deciding to remove the prefix for some reason.
Also, when you get it going it will most likely show a security warning rather than loading straight up.
Old September 14th, 2023, 01:08 PM   #26
mk42
United States
mk42 is offline
I noticed on the website user administration section you created an admin user with a password, but it still had minimum permissions. It shouldn't prevent you from even getting to the web page in the first place, but it might mean you can't do anything once you get there. Try checking all the permission boxes for Admin, at least for now.
I'd say at least a third of the time my PLC isn't doing what I want, it's because I either forgot to DL or did a SW only DL (no HW) or didn't notice that the DL never actually happened because of a sneaky compile error. try to do a full download again, just to check.
Old September 14th, 2023, 01:30 PM   #27
Mas01
United Kingdom
Mas01 is offline
@puddle, no worries mate...the PLC is not networked, no router. It just sits on my desk, connected to the HMI and development laptop.
@jesperMP and @mk42... I'm back home so I'll try out your suggestions first thing tomorrow. Dunno what I'd do without the help on this forum... and I'm meant to be the company PLC "expert" LOL.
Old September 15th, 2023, 04:55 AM   #28
Mas01
United Kingdom
Mas01 is offline
I've tried Chrome, Firefox & Microsoft Edge - all of them are unable to reach 192.168.0.1
Does it matter if PLC is in RUN mode or STOP mode?
Old September 15th, 2023, 05:59 AM   #29
Mas01
United Kingdom
Mas01 is offline
UPDATE: I connected the ethernet cable to another computer, but I still can't access 192.168.0.1.
I will keep investigating this. It's so frustrating!
Old September 15th, 2023, 06:28 AM   #30
Puddle
United Kingdom
Puddle is offline
Have you tried it with WiFi disabled?
Failing that, see if another IP address works.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens S7/TIA v18: Only allow input of alphanumeric values...... Mas01 LIVE PLC Questions And Answers 19 September 6th, 2023 09:55 AM
Siemens S7/TIA v18: Is there a "first scan" in TIA portal?... Mas01 LIVE PLC Questions And Answers 4 September 1st, 2023 11:29 AM
Siemens S7/TIA v18: What does "Object Number" mean?... Mas01 LIVE PLC Questions And Answers 4 August 31st, 2023 11:41 AM
Siemens S7/TIA v18: Data conversion DTL to DATE...... Mas01 LIVE PLC Questions And Answers 1 August 29th, 2023 09:16 AM
Siemens S7/TIA v18: WinCC: F7 needs to SAVE data AND advance the screen...... Mas01 LIVE PLC Questions And Answers 9 July 14th, 2023 09:45 AM
