I have a bit of an in-depth question on the operation of dynamic braking / regen. What I know and please correct anything that I am incorrect on...
Anytime the load is operating faster than the drive command, the motor will act as a generator causing a rise in the bus voltage. This is increase is dissipated by a resistor on the DC bus which is controlled by transistor (chopper).
An asynchronous motor will act as a generator when required capacitance is added to the stator and shaft speed is higher than rated motor RPM. The motor can also act as a generator when voltage is added to the stator to excite a field.
So when a VFD is running a motor at 60hz and is commanded to stop 0hz, how can the motor act as a generator when th shaft speed is obviously lower than the motors rated RPM. I’m guessing that through the drives transistors a field is still being generated in the stator allowing the motor to act as a generator. Is this correct?
Also how does the power flow backwards through the IGBTs to get back to the bus?
