TheWaterboy
What is the latest model Controllogix to support DF1 Serial?
Shouldn't that read 1756-L6x and 1769-L32E/L35E?The 1756-L6x and 1756-L32E/L35E supported DF1 through their onboard RS-232 ports.
I believe there is a USB to serial adapter, no? So even if your PLC is using USB or serial, you can communicate with your laptop with the adapter?
I believe the USB port on AB PLC's is for programming only. They aren't "PLC to PLC" communication ports. Plus, in order to get a USB to Serial adapter to work you would need there to be a driver installed on the PLC which doesn't exist.
