Disabling UDT member in Ignition using expression
Jan 2014
VA
27
I'm working with Ignition 8.0.7 and am trying to enable/disable certain UDT members based on what PLC the UDT is originating from.
I have a parameter called {PLC_NAME} and I'm trying to evaluate a true/false expression in the "enabled" property of a UDT's member.
It seems no matter what I do, I can't use an expression to disable a member.
I've tried the following
if( ( {PLC_NAME}==name1), 1, 0)
if( tostring({PLC_NAME})==name1), 1,0))
if( tostring({PLC_NAME})="name1"), 1, 0)
Just to see if I could get the enabled functionality to even toggle, I tried:
if(1,0,0) which should disable the member regardless. However that gave me "error committing edit value"
I received the same error when I tried if(true,false,false)
Does Ignition not allow expressions to define when a member is enabled or disabled?
From Ignitions Forum
Tag properties (with the exception of certain alarm properties) can’t use expression bindings, only bindings to UDT parameters. The reason the editor is there is in case someone wants to make a parameter reference using an offset, such as {someparam+1}. The editor is confusing in that it uses syntax highlighting for expression functions, and we have an outstanding ticket in our system to revamp that editor page to make it more clear that expressions aren’t allowed.
I hope that helps
If Chris' post is correct, perhaps you could within your UDT create an expression BOOL tag, and put the expression in there. Then bind your enabled tag property to that expression tag?
PanelView +7 Series B ME station disables network adapter on panel when I downgrade to Rev. 9 or 10. Used to work before with the Series B panels...
484
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
943
I have an application that's in initial development. Two sets of 5700 racks, 4 axes each, separate power supplies, separate cabinets The two...
630
I haven't found this on a search of the forum or Rockwells KB. Is there a way to disable RSL/Studio5K from creating a grace period license? I...
27
5,360
Hey folks, We have a PView+ 700 here that I've gotten set up. I've been told that it's possible to disable the touch screen on these but I can't...
2,199
