RSLinx Classic 2.59 - Release Notes
I'm going to go ahead and say "Reformatted Help files to a filetype compatible with Windows 7" is not on the Features list.
EDIT: I wasn't looking very carefully at the "Unblock" selection for the file. CHM is basically obsolete precisely because of this sort of security issue and I'm disappointed that RSI is continuing to use it.
But I'll throw all that out in trade for a Windows 7 64-bit driver for the good old 1784-PCMK !
There is a tech connect only note that explains how to make them viewable.
http://rockwellautomation.custhelp.com/app/answers/detail/a_id/41861/related/1
Not sure why it is such a big secret. Basically, the file properties of the chm file you downloaded must be checked and then you must click the "Unblock" attributes button.
EDIT: Not sure if that is the same issue Ken is having. Seems I had to install a patch for some other software on this Win7 64bit machine to get the help files to work in another application.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
180
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
153
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,555
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,132
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,385
