Without the original application it will be impossible. If you can get the code off the supplier it would be possible to re-program it using Beijers E-Designer software, however this has been superseded. I suggest that if you do get the code, post it and one of us could at least give you an idea of the structure so you could use a GOT or Beijers current HMI to replace it but you would need to buy the programming software and a new HMI & lead.
