I find the answer on wikipedia very good. And it's only a few clicks away...What is fuzzy logic.?
http://lmgtfy.com/?q=fuzzy+logic+labviewhow do use fuzzy logic in labview?
I can't take anything from you, can I? At least one question of your homework really should be answered by yourself...What is difference between PID-Fuzzy-neural networks?
In what way? Provide an example.The biggest difference between PID and Fuzzy, is the ability to change the control algorithm, depending on the input or more as one input can be used.
The 'neurons' of a neural net use sigmoids instead of linear ramps most commonly use in fuzzy logic. FL can use sigmoids too but it complicates things.Neural and fuzzy looks very much the same, but the neurons are all separate ad needs aal a definition.
A PID can be one simple line and that is good because the code requires few resources.PID is one simple arithmetic line, fuzzy needs more calcinstructions (nowadays no problem )
I see lots of programs written in fuzzylogic.
I don't think they were meant to be though!
