Citect Substitution Syntax question
EICS
Dec 2008
Melbourne, Australia
323
I have another Citect Substitution Syntax question
for a function below.
FUNCTION
TEST(STRING sTagbase)
// Digital Variable tags in database are FM_D1FIB1_TRIGGER, FM_D1FIB2_TRIGGER, FM_D1FIB3_TRIGGER etc
// STRING sTagbase is passed from another function as a String ! the prefix of tags for 9 devices e.g. FM_D1FIB1 or
// FM_D1FIB2 or FM_D1FIB3 etc
INT = bTagSub; ! Boolean substitution i want to use to replace tags
// i need to do a substitution below for the following example'FM_D1FIB1_TRIGGER' Digital tag
// something like sTagbase+"TRIGGER" = 1; but i cannot get the syntax correct
// the code below works but its specific to one device only
IF FM_D1FIB1_TRIGGER = 1 THEN ! Tag here needs to be substituted for sTagbase+"TRIGGER"
Do some code here .......
END
END
Since you need the value of the tag and you are constructing it dynamically you need to do a TagRead.
INT bTagSub = TagRead(sTagbase+"TRIGGER")
I have created a project in Citect SCADA using a number of genies, however the order that the substitution parameters are listed when implementing...
3,701
Hello, I have a running project on Citect v5.42 and simatic net v6.4 I have created a new spare PC and loaded all software like Citect, station...
66
Hello everyone, In a factory where we installed Citect 7.20 the computer began to show the first signs of end of life. They never considered...
72
I have a running backup of Citect and plc and I want to make a spare PC station so I have installed the win XP and somatic net v6.0 and import the...
118
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
274
