WinCC Flexible as a Scada Light for around 7000 tags... ?
userxyz
May 2002
any
2,768
Hellow
A customer of ours has many MP377 HMI's in his company and wants to be able to control everything from one PC in the same way as the HMI's. Some of the HMI's have more then 2000 tags.
When an HMI dies, he wants to be able to control with WinCC Flex Runtime on the PC.
Another thing is being able of trending varibles on a PC.
We have a license for 4096 tags. But, this is not enough, the total amount of tags is around 7000 tags.
All together:
- All HMI's in one PC Runtime project, all connected at once.
- Multiplex by using words instead of bits... group bits in arrays, in this way being able to connect around 7000 tags with a license of 4096 tags.
Are there people out there who have alternatives for this kind of idea ?
The multiplexing thing is a lot of work...
What if we use change connection... are only the power tags used for the chosen connection ?
I was more thinking in a way like:
Making a PC Runtime project and only show what's needed but being able to start an HMI from the Flexible ES.
Ideas ?
Thanks in forward,
Kind regards,
Gerry
Hi Gerry.
I suggest that you make a series of "emergency" PC RT projects from converted MP377 projects. Let these be available on a PC with a PC RT license, only for the purpose of running one PC RT in case one of the MP377 panels are down. That will take the least effort and probably cost you only one 512 tags license.
As to the trending, then you probably do not need to trend 7000 tags, but maybe a much smaller number of tags. I would do that on another PC with a PC RT just for that purpose.
If you need to run several converted MP377 projects at a time, or an MP377 project on the same PC as the trending project, then maybe you should consider to run one or more PC RT in a VMware virtual machine. You need a license for each of these. I believe it will work well as long as the online conection is via ethernet and the target PLCs are "reachable" from the VMware vitual machines.
Sounds good
Hi Jesper,
Sounds good enough for me. Now I have to convince my collegue that it can be done like that. His Idea was to change lot's and lot's of tags... for example, M200.5, has to be MW200 bit 5 (array). This to prevent lot's of bittags. To me it looks like waaaaay too much work.
What you say is very interesting: I can use VMware to let things trend in one Runtime and another via VMWARE to takeover panels... they will have ethernet simultanious ?
Thanks !!
Kind regards,
Gerry
Hi Gerry.
vmware
Jesper,
Just a little question that I can't get of my mind...
When one flexible runtime is running with an ethernet connection, can a second flexible runtime (MP377) from VMWARE on the same ¨PC connect too ? Both WinCC Flexible Runtimes will have connection without probs ?
Kind regards,
Gerry
Hi Jesper,
Thanks !!
Kind regards,
Gerry
Yes it will work.
The VMware virtual PC must be "bridged" to the host PC. The target PLC must be reachable from the virtual PC, i.e it must respond to a ping.
edit: The virtual PC must have its own unique IP address that isnt used by any other PC, real or virtual.
Jesper
Thanks Jesper.
I've red in an other topic that you did some experiments with VMWARE and WinCC Flex :).
It's a great help, thanks very much !!
Yes it will work.
Testing Testing...
Jesper,
I did some tests and I have a lot of progression =>
Here I am at our office, so I needed to use VPN for the tests.
- I installed S7 and flex on a VM.
- I build up a VPN from my machine and the VM as well.
- Both can ping to the PLC.
- Runtime (fwx files) works.
I did not test Flex Runtime in VM and my machine at the same time yet, but I believe it will work.
Like u said, I setted VMware bridged and My machine and VM have different IP's in the same range.
BUT,
Then I installed on a clean VM only flex Runtime and I copied the folder HMIEs. Started the Runtime (fwx) of the panels in that Runtime, but they do not get online. Ping reply ok. In the other VM where Simatic is installed, there is does work...
I'm searching for the problem at this moment...
Do you have an idea yet ?
Yes it will work.
Can't
No, it's more then that...
The network adress is 192.168.1.38.
Status: connected.
But I cannot go on google or VPN in this Virtual Machine...
The Network setting is still bridged, but... it does nothing... So connecting VPN doesn't work either at this moment... I tried several vmware OS, but they do all the same ??
Any ideas ?
Jesper,
BUT,
hmmm
Getting dissapointed in Vmware:
Status: connected.
Any ideas ?
Hmmm
Connection with a VM where no Siemens software is installed on => www.google.be np. Connection with VM where Siemens software installed on, no internet or vpn possible. This morning I could connect with flex thrue vpn without a prob... I installed updates on the vm, Maybe that's the prob ??
Okay
Okay
Found something... pretty strange...
I had one XP that still made internet connection in VMware. It was started from an external Hard Disk. When I copied it to my C, then I have the choice... moved it or copied it, I allways said copied. When I did that the last time, running the VM on the external drive np, after copied on local drive no internet connection anymore. Then I tried moved it !!!
THIS WORKED.
What's the difference, well...
When it worked on the external drive, the IP in the VM XP was 192.168.1.27. When I said copied is was 192.168.1.38 (don't work), when I said moved it remained 192.168.1.27 wich was good.
Isn't 192.168.1.38 allowed ?? Why did I have this problem ?
I can work now with the VM that works, but it gave me a lot of extra searching work.
regards,
Gerry
Have been away for a while.
I cannot say what your problems where exactly. I dont have the same problems. And I know that for example Siemens own support people are using various Vm's to support a multitude of software versions, so it must work for them too.
Hey
Hey,
These were XP vm's from the internet, I will install my own OS in Vmware today. Once it works, I will not use "copied" anymore but "moved" instead... "copied" does something with the networksettings..
Regards,
Gerry
strange
strange problem now...
I installed xp in VMware, installed VPN Aventail, have connection, can ping and got ping reply. Installed WinCC flex Runtime SP2. Not ES. Installed necessary licenses.
Run an fwx file... doesn't connect, all ###
?? Do you have an idea ?
On my local laptop it does work when I hit the play button in wincc flex es
Hey,
Regards,
Gerry
oeps
oeps
pg/pc forgot, ok now
m working on wincc2008 flexible Scada, what should i do to generate a message on cell phone on the arrivel of any fault (mentioned in the program)...
1,064
Hello all, I want to Control & Monitor 8 different S7-200 CPU 226 PLCs through Wincc Flexible SCADA. I am trying to communicate through...
7,000
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
69
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
735
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,522
