Panasonic PLC-FPWIN
sweety616
Jul 2005
New Jersey
36
Dear friends:
If any of you have experience with Panasonic FPWIN software. I am looking to program the following truth table
X0 X1 X2 Y0 Y1
0 0 0 0 0
1 0 0 0 1
0 1 0 1 0
0 0 1 1 1
How do I implement this? Any help is really appreciated
Sweety
hi,
I only use nais plc's and that FPwin but am a little confused about what you are trying to do. What are the 3 inputs being labelled as (function) and what do the 2 outputs indicate?
thanks
Hello.
Are you trying to do something like this?
X0 X1 X2 Y1
X0 X1 X2 |
X0 X1 X2 Y0
X0 X1 X2 |
X0 turns on Y1
X1 turns on Y0
X2 turns on Y0 and Y1
Hope this helps.
I am involved with the Panasonic FP7 for my final year project. I am doing a water distribution system and I want to use interrupt program for the...
726
Hello friends. I have a problem after a backup attempt. I lost all programming in plc panasonic afpx c30t, is it possible to perform a restoration...
923
Currently we are using panasonic FP-e and want to connect the encoder and use the high-speed counter to let the motor receive the signal Is there...
1,077
Hello Guys, I spent some time searching the web to learn how to generate the report (to be printed out or to be saved as pdf file) which would...
1,207
So I started working on this old italian machine and it has an FP0 plc, I am using the fpwin gr 2.7 software and it lets me connect to it and...
3,157
