Ones_Zeros Member O Join Date Feb 2014 Location at work Posts 367 Apr 7, 2018 #1 How is the best way to toggle 2 bits in PLC with one button in Wonderware? Preferably without having to script it? Thanks
VAN Member V Join Date Apr 2012 Location Wa Posts 509 Apr 7, 2018 #2 ONS to the PLC and have the code to control the toggle in the PLC.
lostcontrol Lifetime Supporting Member L Join Date May 2009 Location NeverSayNever Posts 1,070 Apr 8, 2018 #3 No other way than scripting it.. Assume your using SP (based on previous posts..) Perhaps cleanest way is to have a data change script, then to the toggle in the script, with last line making the second tag = the first. But, as we seem to miss often, why the need to toggle 2x tags. ??
Bit_Bucket_07 Member Join Date Feb 2013 Location Southeast US Posts 1,875 Apr 8, 2018 #4 Ones_Zeros said: How is the best way to toggle 2 bits in PLC with one button in Wonderware? Preferably without having to script it? Thanks Click to expand... Assign Bit1 to a toggle pushbutton and write one line of code in the PLC to make Bit2 = Bit1.
NetNathan Lifetime Supporting Member N Join Date Nov 2011 Location Corona, CA Posts 2,199 Apr 8, 2018 #5 Action script on button up.. Bit 1 = 1 Bit 2 = 2
Bit_Bucket_07 Member Join Date Feb 2013 Location Southeast US Posts 1,875 Apr 8, 2018 #6 NetNathan said: Action script on button up.. Bit 1 = 1 Bit 2 = 2 Click to expand... I'd go with: Bit1 = NOT Bit1; Bit2 = NOT Bit2; On either button down or button up.
NetNathan Lifetime Supporting Member N Join Date Nov 2011 Location Corona, CA Posts 2,199 Apr 8, 2018 #7 NetNathan said: Action script on button up.. Bit 1 = 1 Bit 2 = 2 Click to expand... Was I nuts on this...."Bit2 = 2"???? This is better route: ********** If Bit 1 =1 THEN Bit 1 = 0 Bit 2 = 1; ELSE IF Bit 1 = 0 THEN Bit 1 = 1 Bit 2 = 0; ENDIF; ENDIF; ********** This is a simple button script... Is there a reason not use a script?
NetNathan Lifetime Supporting Member N Join Date Nov 2011 Location Corona, CA Posts 2,199 Apr 8, 2018 #8 Bit_Bucket_07 said: I'd go with: Bit1 = NOT Bit1; Bit2 = NOT Bit2; On either button down or button up. Click to expand... What do you do if both bits in plc = 0 or 1? Last edited: Apr 8, 2018
Mara Member M Join Date Jan 2017 Location Finland Posts 86 Apr 9, 2018 #9 NetNathan said: What do you do if both bits in plc = 0 or 1? Click to expand... Maybe code should be: IF <button> THEN BIT1:= 1; BIT2:= 0; ELSE BIT1:= 0; BIT2:= 1; END_IF
CommissioningMan Member C Join Date Sep 2017 Location Denmark Posts 146 Apr 9, 2018 #10 NetNathan said: What do you do if both bits in plc = 0 or 1? Click to expand... Both will just be inverted. Mara said: Maybe code should be: IF <button> THEN BIT1:= 1; BIT2:= 0; ELSE BIT1:= 0; BIT2:= 1; END_IF Click to expand... Now you are just setting bit 1 high as long as you keep the button pressed, and bit 2 high when you release it, what's the point of that? Am I missing something or isn't it just a question of toggling two bits from one command?
Bit_Bucket_07 Member Join Date Feb 2013 Location Southeast US Posts 1,875 Apr 9, 2018 #11 NetNathan said: What do you do if both bits in plc = 0 or 1? Click to expand... That script would invert the two bits regardless of their original state. I understood the OP to be asking how to toggle two bits at once. I never got the impression that the OP wanted the two bits in question to always maintain opposite states.
Mara Member M Join Date Jan 2017 Location Finland Posts 86 Apr 9, 2018 #12 CommissioningMan said: Now you are just setting bit 1 high as long as you keep the button pressed, and bit 2 high when you release it, what's the point of that? Am I missing something or isn't it just a question of toggling two bits from one command? Click to expand... Yeah, you are right with this. Sorry
NetNathan Lifetime Supporting Member N Join Date Nov 2011 Location Corona, CA Posts 2,199 Apr 9, 2018 #13 I guess we lost the OP....
