What is Neutral Text
seron
Jul 2018
Malmö
I'm new to Rockwell Studio 5000 but not to programming. I tired to find a description of Neutral Text syntax but could not find anything other than references to it in the programming manuals and online help.
Is there any documentation that describes its syntax?
go to an existing rung ... go into the edit mode (usually just a double-click on the rung number) ... now double-click the rung number again ... you should see some text such as "XIC Local:1:I.Data.0 OTE Local:2:O.Data.0" ...
there is a setting at the left side of the window which lets you select either "Neutral Text" or "ASCII Text" ... play around with those settings and see what you can figure out ...
notice that ASCII text is "cleaner" ... Neutral text requires a more formal syntax ... in other words, more brackets, more commas, etc. ...
when you Paste a rung into your program, you usually have to use the Neutral text setting ...
TIP: leave the setting on ASCII text - then click (once) to highlight the END rung with a blue cursor ... now type something like XIC CTU and see what happens when you hit the Enter key ...
I don't know of ANYONE who types in Neutral text - but quite a few programmers who are proficient with the keyboard will type their ladder rungs in by using ASCII text ... you probably don't need the Neutral setting - except when you're Copying and Pasting rungs ...
this is all that I have time for right now ... I hope that it helps ... welcome to the forum ...
Hi all, dont know if this forum is the correct one, but I know many here could answer this question.. There is a project, where a subcontractor...
2,145
Just want to check if the following is kosher. Whomever did this motor control took a leg off 480 and use it to neutral for 277VDC to light up a...
17
3,452
I have an OEM requesting a 15A 120V circuit in their control panels. This control panel is going on a moveable piece of equipment so it will not...
2,712
This is a odd thing to ask and I'm sure it's not allowed, but I'm curious about the problems and effect from taking g a 480v Delta system (no...
21
6,158
Is it OK to run the Neutral wire thru a disconnect switch for a electrical control panel as shown below? If not, can someone elaborate as to why...
20
7,862
