Help with C-More EA9 HMI and UniDrive SP
mjisaacs
May 2005
Morganton, NC
66
I am trying to communicate from a EA9 HMI to a unidrive SP via port 2 (2 wire RS485) using the ModBus RTU protocol. I have connected a cable from the 3 pin terminal on the HMI. I have connected it via pin 2on the UniDrive RJ45 to +, pin 3 on the Unidrive to LG, and pin 7 on the Unidrive to -. I cannot seem to get it to communicate. i cannot push numbers into the drive or receive. I am getting a timeout error on the HMI. Has anyone done this before? My settings in the HMI are:
slave address 1
Baud Rate: 19200
Protocol: RTU
Parity: None
Stop Bits: 2
Select RS485: Yes
Control RTS: No
Require CTS: No
Byte Order: High Byte, Low Byte
Word Order: High Word, Low Word
Character Order: Char1, Char 2
PLEASE HELP!!!
duh moment! I had a wire backwards. I can now communicate. BUT...I can READ a 32 nit number, but when I try to WRITE a 32 bit number, I get a 0x0002 error. I can change the number thru the SOFTWARE (not writing from HMI) and I see the correct number coming back to me. It is simply NOT ACCEPTING what I write to it.
HELP!
Hello everyone, I have learned a lot about incremental encoders today. But I am down to one last issue and it's a big one. I have 8 incremental...
1,744
I've downloaded my cmore and clx projects to their respective devices and have established communication and control. One of the screens co2 has...
3,045
Hi, i uploaded program from Allen Bradley PLC, i need someone to help me elaborate more on this uploaded project will appreciate any help thanks
2,114
So far so good, Almost done with this migration stuff Someone please help me on this one: ERROR IS: ''Bit and LSBit triggered alarms that used...
1,665
I'm using a Do-More and a Leuze Electronic ODSL 9 sensor to monitor a large hydraulic cylinder. I have to calculate and log the velocity. I...
1,343
