Unidrive SP + Digitax + ??? new system
BenE64
Jul 2015
Queensland
Hello, I am currently trying to set up a motor and servo drive for a basic milling machine head. I picked up a Unidrive SP for the main motor and to try and keep everything compatible I got a Digitax drive for the servo to control Z axis feed.
I don't want to overly complicate things, this is my first rodeo as it were. I think I can configure the drives separately to run stand alone, manually control speeds etc but I would like to have the feed controlled in geared mode to the spindle, after reading the Emerson guides I bought an EZ motion module to install in the Digitax and I need to get a extra encoder module (universal or standard?) to get the signal from the Unidrive. This is as far as I have got, I am unsure on the best way to tie it all together with a HMI or another PLC?
I basically want to set spindle speed and the set a feed ratio on the z axis, manually start and stop, reverse, eventually I would like to be able to set a travel distance then reverse to home that could be entered in the HMI then manually start the cycle ie drill a hole to set depth return to home.
Can anyone suggest the best way to go forward? I have a unitronics v130 plc spare but would rather it all controlled by one plc (EZ motion or applications plus if need be) and a hmi if that is easier to learn.
Thanks in advance,
Ben
hello everyone, trying to find a way to read/write memory of the PLC that is inside Unidrive M700 over Ethernet (modbus TCP) using device/server...
559
Greetings experts, We have a 'Control Techniques' Unidrive 3405 in an older machine. It appears that the drive parameters are recorded in a .CTD...
722
Hi We intend to replace our LENZE EVS9326 EP with a Control Technique Unidrive SP. The machine is a simple one; PLC send ABZ pulses to the drive...
2,035
Looking for a Modbus address manual for M700. Modbus address is same as the Parameter number for 16Int parameters. But it is different for 32Int...
1,987
Hello, new here, so let's start :) I am having some issues with kinco mt series hmi, mt4414te. Kinco and unidrive sp are connected via modbus...
3,899
