plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old January 20th, 2005, 10:31 AM   #16
pstephens
United States
pstephens is offline
pstephens's Avatar
Looks nice, Jim.
I thought you said you were going to do the wiring last night, not the plumbing... ??
Keep it up!
Paula
Old January 20th, 2005, 12:01 PM   #17
jdmartin8
United States
jdmartin8 is offline
Well, Paula, I guess I don't have an excuse !! I went ahead and made the 'stand' as it will make it just a little easier to wire up, with the panel being supported.
Understand, that since I work for a major water treatment corporation, I have an abundance of PVC plumbing parts, so I just used what I had to make the stand. It's very sturdy, non-conductive, and best of all, FREE !!!
Terminal block mounting tonite, and wiring will be at least STARTED !!
Thanks..
Jim
Old January 20th, 2005, 01:03 PM   #18
elevmike
United States
elevmike is offline
elevmike's Avatar
Just a suggestion...
If you have high speed/counter inputs on the little AB, you might want to install a quad encoder with a little crank wheel.
__________________
If you think you can do a thing or think you can't do a thing, you're probably right.... Henry Ford
Old January 20th, 2005, 01:27 PM   #19
scooby blue
United States
scooby blue is offline
Where is the federal horn?
Old January 20th, 2005, 03:28 PM   #20
jdmartin8
United States
Scooby...... ????????????????????
Old January 20th, 2005, 04:53 PM   #21
scooby blue
United States
Smile
You know one of those ear piercing horns mounted right there on the stand. That would wake some people up.
Old January 20th, 2005, 05:14 PM   #22
jdmartin8
United States
Don't think I haven't thought of that !! Problem is, I'm probably going to be the only one using this thing, and I HATE IT when my sleep time is interrupted !!! hehehe..
Jim
Old January 20th, 2005, 07:54 PM   #23
Thomas Sullens
United States
Thomas Sullens is offline
Thumbs up good job
Great looking trainer beerchug
Something you might want to do is put some N.O. little PBs under your toggle switches. Just put them in parallel with the toggle switches. Then you can have the best of both worlds. You`ll see the benefits of this when you start tring to simulate your program and watch it work.
Old January 20th, 2005, 08:22 PM   #24
jdmartin8
United States
Great idea, Tom. Never thought about putting more switches in parallel. And I just happen to have a drawer full of PBs. !!
Thanks...
Jim
Old January 20th, 2005, 08:41 PM   #25
Eric Nelson
United States
Eric Nelson is offline
Eric Nelson's Avatar
Quote:
Not even finished with the wiring and it looks like you're already gonna need a bigger piece of plexiglass...
beerchug
-Eric
Old January 20th, 2005, 08:51 PM   #26
jdmartin8
United States
Quote:
beerchug
-Eric
Naw......... Plenty of room on the plexi, plenty of switches, plenty of wire, fresh out of energy !!!!!!!!!!
Jim
Old January 20th, 2005, 08:59 PM   #27
CaseyK
United States
CaseyK is offline
CaseyK's Avatar
Location: In the cornfields, on the prarie, outside Chi-Town, a few miles beyond the boondocks.
Lightbulb Federal Horn
Nothing like a nice loud alarm horn.
Should be controlled by a momentary push buton that has a latching circuit in the PLC. Button should be marked "Do Not Push". Works even better when PLC runs of a battery, so the alarm doesn't shut off when you pull out the line cord.
By the time you are done, there will probably be 2 or 3 pieces of plexi glass as "annexes", and 2 or 3 more plc's networked together.
PLEASE do NOT do a traffic light, railroad signals are more fun anyway!
regards.....casey
__________________
73 de casey nine eye aitch
Old January 20th, 2005, 09:08 PM   #28
Bitmore
United States
Bitmore is offline
Bitmore's Avatar
Good thing there is an E-Stop button!
Just in case you get carried away!
Nice looking trainer...
__________________
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible. There are no prima donnas in engineering." Freeman Dyson
Old January 21st, 2005, 04:31 AM   #29
ayman metwally
Egypt
ayman metwally is offline
looks nice
It will be a good idea to install a small Circiut breaker as the main feeder for all the compnents of your panel, Two benfits achived from this:
1- protection.
2- a manual switch for conneting/disconnecting the power.
__________________
Ayman Metwally
Old January 21st, 2005, 06:35 AM   #30
jdmartin8
United States
Ayman,
I have already installed a fuse for the 120VAC, and another for the 24VDC. The E-Stop is wired to remove all 120VAC when activated. I know that this is not the 'field' way to wire the E-Stop, but I believe it will suffice for a trainer.
thanks...
Jim
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
MPI comunication Manuel Raposo LIVE PLC Questions And Answers 22 July 16th, 2007 07:24 AM
Buiding a PLC Trainer Using Allen Bradley LIVE PLC Questions And Answers 6 July 17th, 2004 03:13 PM
Lost idea build a PLC trainer Deer LIVE PLC Questions And Answers 2 June 24th, 2004 03:13 PM
BUILD YOUR OWN PLC TRAINER Vetteboy LIVE PLC Questions And Answers 5 March 31st, 2003 11:58 AM
Real World Problem Vietnam Bob LIVE PLC Questions And Answers 8 November 23rd, 2002 03:03 PM
