Beckhoff problem starting runtime with VISU
walkir
Feb 2019
California
32
I am working on a project and I have CP6706-0001-0050 where I need to make PLC + simple VISU. It has all licenses and PLC is running fine. But when I create even empty VISU screen, Visualization Manager with Target Visualization then CP doesn't start in run mode any more.... Although all compilation goes without any errors while I try to 'run' I am getting errors:
Severity Code Description Project File Line Suppression State
Error 2/1/2020 8:32:44 AM 794 ms | 'TcSysSrv' (10000): Sending ams command >> Init44\IO: Set State TComObj PREOP OP: Check for autostart >> AdsWarning: 1804 (0x70c, NoString) << failed!
Error 2/1/2020 8:32:44 AM 790 ms | 'Port_851' (851): Could not link external function <extref>MBM_POOLGETBLOCK</extref>
Any idea what am I missing?
In case someone ever is going to have a similar problem:
I got in touch with Beckhoff's support and they also couldn't figure it out. The solution was to get an updated CP image...
I am trying to use my Beckhoff PLC to send emails. I am using a Gmail account that I just created. Apparently Google has removed “Less Secured...
1,130
Hi, I'm trying to connect to server to send some data and I'm having problem with HTTPS connection, specifically with TLS set-up. I'm getting...
2,253
Hello, I am responsible for implementation of Vijeo Citect 7.4 SCADA in my company. I want to connect to Beckhoff PLCs by using Twincat OPC...
1,977
Hello, I work for a manufacturer in the precast concrete industry. I had to control the system shown in the video...
2,752
So, I got this Beckhoff embedded PC for some testing purposes of various K-bus terminals. Before I worked with CX1010 and had no such problems...
11,940
