Automatic Wire cutter machines
Orn Jonsson
Apr 2002
Boise Idaho
125
Anybody with a panel shop bought or used an automatic wire cutting / stripping machine?
I am wondering which brands are the bast bang for the buck... small to medium volume.
I threw together an AD plc based feed-to-leingth stepper system in an attempt to build my own wire cutting machine. The controls work fine but I am having trouble finding a "cutter" that I can use with a small air cyl or electric solenoid to do the actual cutting. Any input appreciated...
Orn
There was a pretty lengthy thread a while back about an automated wire feeder/cutter a while back...
See if THIS helps any, and post back if you have any questions.
That thread was on metal wire.
Orn what you are looking for can be V-blades, Radius blades, or die blades. V-blades (there are several types) can eliminate changeovers for different wire sizes. Die blades offer better precision but will require changeovers.
This is a company that sells auto wire cutters and parts, they may be able to assist you with the blades, holders, etc.
http://www.eraser.com/catalog.cgi?mode=details&product_id=2641
Do any of you guys have one? Likes, dislikes, things to watch out for? Cost? Thanks.
3,258
Hello everyone, I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB...
551
Hello everyone, I was hoping someone with a lot of experience with Automatic Device Configuration would chime in with any of your thoughts on this...
1,793
Hello. At my job I get from clients lists of their inputs and outputs (hundreds of them) and what they want the program to do. So I have to type...
1,313
For some reason the PLC (TM221CE16T) saves all Memory Bits and Memory Words automatically so after a cold restart it restores not only %MW0 to...
18
4,713
