Communicating with a Foxjet/Marksman Elite using ControlLogix ( RS Logix 5000 )
Aug 2016
Virginia
343
Good Afternoon ,
I was wondering if any of you folks have communicated with a Foxjet Marksman Elite Printer. The reason I ask is that we would like communicate with the Foxjet , and tell it when a shift changes , the time , and allow another pallet to be loaded before changing.
I would like to count cases , and the result of this count , and pallets loaded would determine when the shift would end and what time. Then we can change this time , without an operator manually changing this time.
The Foxjet is a PC , and I am puzzled on how I would write code for this .
Have any of you done this. I am going to call Foxjet tomorrow , but I would like to have a understanding before I get in a discussion with them.
Thanks again for all your advice. You guys are , in many ways a "Career Saver " :)
If the manufacturer has no known solution your best bet, IMHO, if the Foxjet is a PC as you say, is to see if there is a way to use standard tools such as SQL server as a conduit. Data from your PLC can be sent by SCADA or an (intermediary PLC that can access SQL-we use WAGO) to a shared table in SQL which can then be read at the PC. This is an over simplification because I don't know what can be done in the application at the Foxjet end but this perhaps may give you some kind of direction.
Dear All Please help me about Below picture problem.PLC not communicating proper.
176
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
680
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
439
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
353
Have a customer that has a running 1756-l83es, communicating to redundant ABCIP IO servers for Wonderware 2020. This configuration has been...
871
