It is (was) programmed with Protool.
According to the manual for TP070 it should be on the Protool install disk under the \images folder.
I have looked at some old Protool install disks, but TP070 is not there.
That is my problem it should be there but its not and only some versions of ProSave contain and mine unfortunately does not. Then there is the mystery of none of my Microwin SP9 should have TPdesigner which it doesnt. I have also have a standalone copy of TP Designer and that does not have it either. It is almost as if it does not exist.
