Rslogix500 input issue
gouldmx01
Sep 2018
sct
Hey guys, first time poster here and very new to the PLC world, i'll cut to the point:
I am using the rslogix 500 program and i have a photo-eye attached to an XIC bit in my program. I've been having issues with the process recently so i looked to the program and found that the bit that the eye is attached to seems to be flickering very subtlety, before i go trying to change out some photo-eyes my question is ; is this very faint flickering enough to disable my output? it goes on and out multiple times within milliseconds!:confused:
Welcome to the PLCTalk forum !
When you say that the "bit" is flickering, do you mean the indicator on the Input module?
You're either seeing rapid switching of the input state, or a low voltage that is hovering around the 1 vs. 0 threshold.
Either way, start by checking for loose wires (both power and common and signal).
A "flickering" input can definitely cause your logic to not work the way you expect.
+1 For Ken's suggestion. In my experience the problem is almost always the field device or the cable going to it. If this process has been running for more than 6 month, and no changes have been made to the program recently, there is a 99.99% chance that the problem is a bad eye or bad cable. You mentioned flickering, so I'm going to guess bad cable.
Bubba.
PS...
Welcome to the forum!
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
570
Hi, I'm using a Micrologix1500 and it doesnt have the SCP (Scale with parameters) block. I have a 1769-IF8 analog module and need read the inputs...
3,787
when using a micrologix and programing a 4-20ma input does 4ma input = a value of 0 and 20ma = 32767 or is 4ma = 20% of 32767.
1,991
I am new in PLC Programming. We have AB SLC 5/03 and RSLogix500 program. We have a new analog equipment that would be connected to Input Analog...
4,945
326
