Hello everyone,
I had a SLC 5/03 PLC. I created some data files, i.e. N25:0, N25:1, N25:2, N25:3, …, and saved some data in these files. However, after I turned off AC power and turned on again, I made online and found all of these data file contents were “0”. These data file properties were set to “None Protection” because the contents of the files would be changed on HMI ( PanelView 300). The PLC was with battery. The battery indicator was not lit. Why did the PLC can not keep the data when AC power off?
Thanks!
Thanks!
