PeterW
I'm having an issue connecting to a SCADAPack 357 over Ethernet for programming.
I can connect by Modbus/USB fine.
It has an Ethernet address and I can ping it.
When I change my protocol to Modbus/TCP and put the SCADAPack IP address as host address I get the message "The send command operation failed"
If I enable DNP and connect using DNP/TCP to the same address it works fine!!
The default TCP ports are 20000 for DNP and 502 for Modbus.
Anyone had this before and know a solution??
