Curious basic question about multi-signal transmitters, if I have a device that gives a 4-20mA feedback signal (say position or level) I can use the 4-20mA signal as a "limit switch" in a PLC program by designating certain mA values as end positions. In that case, having additional limit switches to mark the endpoints of said device doesn't seem to be very useful except maybe in cases where only open/closed is required, no controller is used, or as a fault sanity check for the signal (using both to check each other, i.e. if limit switch on and feedback in middle range = limit switch fault, for example). Are there scenarios where it is useful to have both, or is one or the other usually sufficient (depending on the application)?
