RS View32 project open when windows starting time
Mvannantn,
Here is one way (out of several methods). You only have to fix Windows so that it will also start the RSView project during Windows start-up.
1. From the Windows Desktop, click "Start", then "Settings", "Taskbar and Start Menu".
2. Now select "Start Menu", then "Customize", "Advanced". Open the "Programs" folder, then the "Startup" folder.
3. In the startup folder, right-click and select "New", then "Shortcut". Now browse to your RSView project folder, open it and select the "(Your Project Name).rsv" file.
Now when Windows starts, it will also start your RSview project.
Using the same method, you can create an Icon on the windows desktop that will start RSView and also start your project.
1. Start Windows Explorer, browse to the directory and RSView Project.
2. Inside the RSView Project folder, right-click on the (Your Project Name).rsv" file.
3.Select "Send To", "Desktop (create shortcut)"
Dear all, Please help me to open this project, I can not open it, cause it appeared some messages that I do not know the reason. Please download...
5,514
This is a total novice question... hopefully I can describe clearly. We have a Windows 7 machine with an Allen Bradley 1784-PKTX Card installed...
1,641
Hey guys, A new client I'm working with has an older system, running RSView32 with AB SLCs and Logix500. I want to copy the existing project and...
5,059
FT View Studio Ver 8.0.0. RSView32 project is about 2007 vintage. From help file: To import an HMI project to a local station application:In...
10,548
Is it possible to import trend data into an existing project? I have previous trend data and would like to import it into the current project.
2,021
