Dear Jesper,
It seems communicating with that 416-2 PCI card type PLC was easier than I thought. I changed the name of the computer to 'Project_PC'. In the Station Configurator I changed the Station Name to 'Project_PC'. Then I created a new project I called 'Test'.
Under the PLC Menu I selected 'Upload Station to PG'. This 'Select Node Address' window came up and I clicked 'View'. Lo and behold there was the 416-2 (and a couple of other things from the Station Configurator). I selected the 416-2. Clicked OK. And, as if by magic, everything appeared in my project. (I did not add additional CPU's - that adds imaginary friends to my project when I do try it.)
An interesting point. First time I did this my PLC had no program blocks. I think I then managed to 'restart' the PLC from a data file and later on when I did this my program got a LOT of data blocks. (The original PLC program.)
So, I can now create OB1 and put some ladder logic in it, upload it to the PLC, and make it go. I can stop and start the PLC from Step 7, and it looks like I am going on line with it.
I think my next magic trick will be swiping an un-loved and unused profibus I/O rack and interfacing it with the rest of my refugees from the scrap heap. Any suggestions for accessing the input outputs over the profibus?
Thanks,
MadPoet.
Thanks,
MadPoet.
