No picture on Siemens S7 HW Device?
russg
Aug 2012
UK
275
I've added a new GSD for some new Cognex Cameras on an S7 project, but the no ones do not display a picture, only some questions marks in a grey box like in the picture attached. Does anyone know if this means the setup is ok? Or how I can get the picture of the camera to display like the rest of them?
Thanks.
Hello russg;
Look at the attached screenshot.
When you downlaod a gsd (Profibus) or gsdml (Profinet) file from a manufacturer such as Cognex, you will generally find a bitmap file attached to it.
If the bitmap is not found in your prhgramming PC (in the correct directory) the icon for a generic slave will be used in the configuration; this is what you show.
When you integrate the gsd/gsdml file in Step 7, it is placed in a ...data/gsd directory in the S7 project tree (search for it on your PC); is a directory next to it in the project tree (sorry, i don't have access to my programming software right now) you will find the associated bitmaps. Put the bitmap file in this directory (it seems the Profibus configurator doesn't do it on its own) and you should see the icon for your slave in the configuration when you open it again.
Hope this helps,
Daniel Chartier
I have been doing a project where I had to use Siemens starter alot and this picture pretty much sums up my experience with it
2,239
Hi I'm working on IFIX 5.5. I need to open a operator prompt to be visible based on the status of a tag that is read from the plc. When i say...
20
1,435
Hi I've inherited an IFIX 5.5 application. A picture is enabled every now and then. I beleive its being enabled by a tag that is read from a PLC...
425
Sorta a dumb question but... I want to duplicate a picture to work on some changes to the graphic.. so "picOriginal", I want a copy of that...
1,892
Don't do much hmi work and what little I do, I use Weintek's and Easybuilder Pro. I gave an old hmi to a mates son, and told him, I would help him...
2,038
