Compactlogix socket connection
barher
Aug 2010
Celaya
I am trying to connect my compactlogix to a socket server located in my computer listening at 192.168.1.99:10000.
When using the msg instruction--> CIP Generic/Create Socket, communication Path 2,192.168.1.99 source element (3 word user defined Family = 2 Port= 10000 Addr=0).
I am using the default source length = 12, but have tested this value up to 20,000; I keep receiving the error 16#0013 "Configuration size too short".
Has anybody accomplished this kind of communication?
I would recommend you to download technote 32962 and test functionality manually
Then you can use Socket AOI provided in the RA Knowledgebase or wrte your own.
Hi, I am trying to connect a L24ER Compactlogix PLC to a GK420d Zebra printer. All my manual reading and forum searches has lead me to believe...
5,411
Hello Gents, I am currently using AB CompactLogix Processor L36 ERM (Mid Range Controller) in an application. One of the device on the network is...
5,542
Hello, I have a panelview plus that reads from 4 different PLC's. 2 of these used to be Micrologix PLC's and someone else went and updated them to...
102
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
156
309
