Micro820 Combining Bits into Word
straes
May 2017
Henderson, TX
I'm trying to combine 16 bits into a word. I'm fairly used to how to do this with a GE PAC, but I'm trying to do it with this much cheaper Micro820.
Thanks for the reply. I suppose I should have stated I read every bit of help document I could have found.
I figured out the solution a few days ago. I didn't actually find any reference to it in any manual or instruction set I could find.
Essentially what I was looking for was how to reference each bit in a word, which as it turns out, is pretty simple...ExampleWord.0, ExampleWord.1, etc. I don't know how it took me so long to find it as it makes quite a bit of sense.
In the end, I just used MOV commands to move _IO_EM_DI_00 to Inputs.0, etc. I couldn't find a way to simply MOV or COP all of my _IO_EN_DI_XX with one simple statement, which was my initial intention. This fits the bill though it takes up more rungs than I'd like.
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
808
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
169
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
900
Hello, I am using a AB Micro820 PLC, via the SD card I want to update the PLC program (not FW). First I created a text file on the SD card with...
293
Hi New to PLCs, up until now I have played with smart relays and the siemens S7-1200 line with TIA. I am trying to get a AB Micro820 to talk to...
304
