Microbrewery controller problem
TDMartin
Nov 2002
High Plains
36
Hi all,
I've been lurking around here for some time and finally have a question to post. It's a shot in the dark but I told the owner of this brewery I'd throw it out here.
They have a Xenia bottle labeling machine that came from Italy. It has a SHS MCU02 integrated OIT/controller. Kind of like a one piece PLC/panelview. I don't have, and can't find any documentation on this controller.
The controller originally lost all the variables but retained the program. After a while of troubleshooting, it locked up, and after a re-boot, the initial screen calls for a keypress. I re-booted this machine several times with no problem, but now it echo's the * character, and after 4 times, refreshes the screen and you get to enter 4 more ****'s.. I tried the password, and it doesn't work either. Does anybody have a manual for this thing that explains this?
I did manage to cob together the wiring enough to get the machine to limp along, and they are labeling their beer. I am trying to get them to spring for a micrologix and a little OIT and junk this SHS thing.
Thanks!
Are you sure it's a PLC. In my experience many of the Italian packaging machines are PC controlled. There's usually an embedded PC controller and they run a custom OS and software. I have one such beast and we had to pay for a guy to fly over from Italy to make one minor change.
I think the option of switching to something more readily supported may be your best option.
You could be right. On your system was there some kind of serial port connector? This one only has phoenix type connectors (6ea.). If they do download to this, one of these connectors should be a comm port. All of them are wired into the machine, but that doesn't necessarily mean they are all IO signals.
71
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
34
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
224
Hello, I have a set of three tanks with their own trio of Hardy 6600 series load cells. Two of them have no issues with where they are at and...
146
Hello everyone, I'm working on a project that involves controlling an array of nozzles within a CNC environment, where the nozzles travel along a...
176
