GE Fanuc 90-30
Jersey Red
Jan 2018
Pittsburgh
CPU 331 will not go to RUN. Can I use a hand held programmer PRG300 to identify the fault. What if the program is pass word protected? A UVPROM is present. Side question What is the reset shorting pins used for on the CPU board?
It has been a long time since I used the handheld, although I still have one. As long as the firmware version is compatible the handheld should work OK. Unfortunately, I don't know what (if any) CPU331 firmware versions are incompatible.
If the program is password protected, you will be granted access to the lowest access level that doesn't have a password. You will need the password to get to a higher access level.
Assuming you get access, you will be able to start and stop the PLC and view the program and hardware configuration. I don't think you can view or clear the fault tables with the handheld. There is no mention of the fault tables in the index of the handheld manual I have (GFK-0402G). All you can do about faults is to look at the %S memory to determine if there are any and whether they are in the CPU fault table or the I/O fault table.
There is also a special key combination you can press during power-up to clear the memory. That would clear everything, but you would then need to enter a new hardware configuration using the handheld. The new configuration would have to be set to load the program and configuration from the EPROM on power-up. Before going to that extreme, I would check the existing hardware configuration to find out the expected power-up behavior.
The shorting pins are to discharge the capacitor that retains RAM memory when the power is off and the battery is dead or removed.
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
107
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
109
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
101
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
169
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
212
