DLMUK
I have to spec a new system using Siemens S7 PLCs, I have not done this before and was hoping for a bit of help.
The system in question is a rotating wheel with hydraulic controls. I need to measure speed, tension and have various alarms and ESTOPS.
Looking at the S7-1200 I think it may be a bit limited. My load measuring device ideally outputs 4-20mA. As far as I can see the S7-1200 only accepts 0-10V AI?
The S7-300 looks like a very costly option in comparison. To me it seems sensible to install two S7-1200s and have one controlling the wheel and the other monitoring my tension/speed and taking the inputs from the ESTOPS. Are there any obvious pitfalls with doing this?
The total system needs:
1 x (4-20mA) AI
1 x (0-10V) AI
8 x DI (7 BOOL and 1 square wave)
4 x DQ (audible alarms)
I will also need to connect a HMI screen with some control and display features (all to duplicate what would be on a physical control panel).
Any advice/obvious pitfalls you could advise me on would be appreciated.
Thanks,
1 x (4-20mA) AI
1 x (0-10V) AI
Thanks,
