Hi, everyone.
I read the CPU948 programming guide, it say cycle time is including that:
The cycle time therefore includes the following:
· the time required to process the cyclic program (system and user
program),
· the time required to process interrupts (e.g. time-controlled
interrupt),
· the time required to process interruptions (errors).
It mean 1 cycle time = run program time + interrupt time + process errors time?? right??
If my program have a timer, it'll work 10s. The CPU will wait 10s to end this cycle time, and restart next cycle time ?? right?? When CPU wait , nothing can do ?? Is it right??
Or CPU use other method to work?? Hope you can explain relative between cycle time and CPU. Thank you!! Thank you !!
program),
interrupt),
