How can i restart my panelview plus 600 in safe mode?
rafaelrio
Jun 2009
RJ
Hello, i´m having serious difficulties to restart a pv plus 600 in safe mode. The application autorun everytime i restart it and i can´t to go to the Configuration Mode Main Screen.
Thanks.
I don't have a 600 here but I know on the 1000 when I power it up there is a self-test screen and then a little flashing white block on the bottom of the screen (don't recall if it is right or left corner). Touch that flashing block and after all of the self tests it will enter Configuration Mode.
Of course, that is a touch version.
OG
If you cannot access the configuration screen using Opera's method (which I believe requires a certain level of firmware), you can download a utility from a/b and put it on a compact flash card which will force any firmware level PV+ terminal to the config screen on reboot.
Paul
I have a Panelview Plus 7 recording data for a customer, who uses FTP to collect the data. Currently it is setup to allow "anonymous" login for...
2,797
Hello All, Is there a way to schedule the ME PanelView Plus 7 (Performance) to reboot from software during RunTime? I do not want to use a Relay...
5,076
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
156
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,030
What b&r cold restart does? does its erase program permanently?
630
