woodward_uk
Hi Guys
I could use some help please with an SLC 5\05 problem that we are having.
One of the sites that we maintain has 12 SLC 5\05 processors which are all connected via a fibre optic network over a distance of approximately 5 kilometers. The network was installed 9 years ago and has been functioning trouble free until a couple of months ago. The fibre converters are Hirschmann RS2-3TX\2FX and the fibre is multimode 62.5\125. There is no redundancy and the network is daisy chained straight through from the first to the last processor.
Also on the network are 10 PC's running Wonderware Intouch SCADA, these communicate through two I\O ABTCP I\O servers. There are also 8 off PanelView Plus HMI terminals at various points throughout the network.
We have recently had a strange occurrence where a number of PLC Ethernet channels appear to freeze up at exactly the same point in time. The green Ethernet LED goes solid and the processor loses all Ethernet communications to the SCADA PC's and to our maintenance laptop running RSLinx. The fault can occur on one or a number of PLC's at exactly the same point in time and each processor has to have its power cycled in order to recover from the fault and to re-establish comms.
The control supply to the processors is derived from a number of separate High Voltage transformers and in some cases totally seperate electric board supplies as they are located at another site. This would appear to rule out a mains power quality problem. There appears to be no pattern to the problem.
Any advice would be greatly appreciated.
regards
Steve
regards
Steve
