Increasing force and also reducing travel distance required
Timeismoney08
Jul 2012
United States
312
I have an application where I need to reduce the travel of an actuator and also double the force. How can you do that manually, without the help of any additional force?
I imagine we can't make one better without hurting the other.
Thank you.
Picture the output shaft of a gearbox. When you double the ratio, for the same amount of torque and rotation at the input, you get twice the torque and half the rotation at the output.
The problem is I need a way to have twice the torque and twice the rotation. I don't think it's achievable when you think of the physics of it, but maybe I can do some additional gearing.
Think about how a pry bar or crowbar actually works, then build a lever to do what you are trying to do. Actuator drives long end of lever, work connected to short end of lever. Both ends are referenced to pivot point for length.
BTW, twice the torque and twice the amount of rotation, (post #4), is different compared to the original definition, (post #1), of the problem.
The First Law of Thermodynamics is inviolable. If you want twice the force and twice the distance you need four times the energy input.
Your second post contradicts your first. Get a grip on your problem and objective, and maybe post a diagram of your system. Until then you will only get SWAG answers. (Scientific Wild A$$ Guess).
I agree with Tom,
your posts are confusing.
please sit down and figure out what you need.
then post it.
double the force and shorten the stroke - ok
double the force and double the rotation - ok.
pick one, you can't have both
james
I agree with Tom,
then post it.
james
Also, it would help to say what your system is, or at least what kind of actuator
This is as if you say I want in my car double torque and double speed rotation by changing only the gearbox ... it simply does not make sense.
You need a 4 times more powerful motor, with all the electrical equipment, gearing and transmission adecuated for the new power
Hello, is there any way how to increase number of nodes of L24ER, which supports up to 8 Ethernet nodes? I'm thinking about additional Ethernet...
3,518
Does anyone can explain me how to do s-curve (for increasing and decreasing speed of the process ) programming in siemens simatic S7. If...
1,867
Im looking into fitting the new 5700 into some of our panels and im basically looking at what is the best way to increase the amount of ports from...
3,987
I have a servo linear actuator that has a stroke of 0 to 6”. The position feedback from the servo control is 0-10V which corresponds to the 0 to...
2,869
Hey guys, I am using some Platinum 385 RTDs and need accuracy down to 1/10th of a degree. It is my understanding, that RTDs have, for the...
26
9,131
