Dealing with Current and Relays
mrowen
Dec 2003
28
I've got a question for you guys about dealing with current requirements when using relays such as air solenoid valves, reed switches, or even relay outputs on PLC's. Obviously, minimizing the current that has to pass through the contacts of any mechanical relay switch will prolong the life of these contacts. Take a simpe case of using a magnetic reed switch to turn on an input to a plc. Normally, manufacturers will say use a RC network with the switch to control surge. My question is why don't folks use a semiconductor such as Jfets, mosfets or darlington arrays to guard against arcing on contacts. Its been a long time since I was in school and devising these kinds of buffers. I can say that it is extremely rare that I see any thing like this on industrial machinery. My current dilema is I would really like to go to a small hall effect chip instead of a reed switch to turn on an input. The problem is the chip I'd like to use requires keeping the current under 40mA. What would be a good way to buffer this signal to the plc input? Thanks.
The current draw for a PLC's DC input circuit is generally less than 10 mA. You're more likely to have problems because your Hall effect chip's off-state leakage current is high enough so that you get false input signals to the PLC. Usually this shows up as an input that, once it's been turned on, won't turn off.
As to the question of why not use darlingtons or MOSFETS as surge suppressors, RC networks and MOVs are in general use for AC circuits and flyback diodes for DC circuits. My guess is that they cost less than the alternatives you're proposing, especially when you're switching higher current levels.
Hello, I am attempting to tune a PID loop on a process. The process involves a valve with electronic actuator that has quite a high deadband...
2,177
Good Morning , We had to change out a L61 with a L71 processor and it seems like our motion control is not the same . Have any of you run...
1,833
I have a single turn encoder controlling my motion project. It is controlling the speed of an elastic web. I have a sensor looking at marks on...
1,722
I'm working myself into a bit of a lather. I'm in need of some assistance with programming an 'Hour Meter' in Codesys V3. I'm using a Wago...
3,822
I have a washer/dryer machine coming from Europe which use 400v/50hz/177A. The machines has some heavy blower/vacumm motors that run on 400v, and...
23
6,606
