Odd VNC issue with Weintek
PLC Pie Guy
Jun 2013
Halifax
1,144
Hey Folks.
I have a bit of an odd issue happening with a Weintek HMI. The HMI itself works perfectly. Its an MT8070Ie.
I have used VNC several times to look at it, but yesterday something was different. It was like using a touch screen that had not been calibrated. I had to click on the screen about an inch above what I actually wanted to touch. So a row of buttons required me to push the button above it to activate the one I wanted. Likewise, when I opened the numeric entry pad, I had to press the number above the number I wanted. If I wanted to press enter, I had to click well above enter.
During all this, the HMI itself worked flawlessly, touch exactly where I needed, this odd situation was just on my laptop VNC viewer.
I tried restarting the Laptop and the HMI but I'm left with the same issue......
Iv been using this laptop with the HMI in this manner for many times without issue before this. It still is in this state. o_O
Im using the Google Apps version of VNC as I normally do.
Any thoughts?????
I can try that.
Just baffling that its been working so long, then it starting acting this way.
Ill get back to it hopefully tomorrow and try a few more things.
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
64
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
427
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
420
Howdy guys - Looking for some insight on the MAM instruction. Had an interesting one today: I performed a controller upgrade on an older system...
436
Hi everyone, curious if anyone has ever witnessed the following comm error: A little history, I had a department PC die, WIN 7. Had to upgrade...
624
