plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 18th, 2018, 07:20 AM   #1
kongshitt
United States
kongshitt is offline
Confused by a motor contactor
So, ran across a part today that I can't really figure out where it would be used.
Its a 4 wire contactor with a NC circuit, when you power the coil it drops power from the load side. To me thats a safety type relay, but I don't see where you would want to use that on a motor. Also, it has 4 high load terminals no AUX like most AB relays.
Just looking for some knowledge because were all here scratching our heads saying why would we ever use this?
Old October 18th, 2018, 07:34 AM   #2
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Maybe for a crane with electromagnet for picking up stuff ?
When the E-stop is pressed, or if there is some kind of electrical problem, the electromagnet defaults to ON. This so it does not drop a ton of steel onto some unfortunate person.
Of course the power supply for the electromagnet must still be on for this to work. I have seen this before as an example of an electrical circuit that should be exempted from the E-stop circuit.
__________________
Jesper
See my profile interests for Q&A
Old October 18th, 2018, 08:15 AM   #3
kongshitt
United States
Makes sense, but like you said, if its it's a power problemproblem, the magnet releases anyway. Thanks!
Old October 18th, 2018, 08:43 AM   #4
scott.lawrence
United States
scott.lawrence is online now
sounds like this was possibly been used in a two-speed motor set-up
Old October 18th, 2018, 09:40 AM   #5
lfe
France
lfe is offline
May the 4th NC contact is for an electromagnetic brake?
__________________
Suppanel HMI
Old October 18th, 2018, 10:19 AM   #6
saultgeorge
United States
saultgeorge is offline
4th N.C. contact could possibly be for a circuit that would power a "motor off" light.
__________________
Detroit City Limit: An Automation Alley Community
Old October 18th, 2018, 11:00 AM   #7
jraef
United States
jraef is offline
jraef's Avatar
Probably an old “DC drive contactor”. The NC pole was used in a braking scheme when you absolutely wanted braking every time the drive turned off, like on a hoist. Not much call for them any more, most everyone has gone to AC drives on hoists now.
Old October 18th, 2018, 11:18 AM   #8
Steve Bailey
United States
Steve Bailey is online now
Steve Bailey's Avatar
I interpreted the OP's description
as all four of the contacts are NC and all four are rated for full current.
kongshitt, please clarify.
Old October 18th, 2018, 03:10 PM   #9
Jeff23spl
Canada
Jeff23spl is offline
i have seen some 4poles with 2 power no and 2 power nc terminal for forward/reverse action on a single coil.
4 NC could also be for load control system. A controler that remove heaters or other non mandatory load to limit the peak read by the utility meter. NC or mechanically held contactor are used to avoid the ''humm'' noise of holding a NO closed in some offices or quiet workplaces...
__________________
Siemens Addict
Old October 20th, 2018, 08:38 AM   #10
shooter
Netherlands
shooter is offline
shooter's Avatar
It is probably used or as a simple on/off contactor as the motor stops when two wires are open.
or can be used to change direction.
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old October 20th, 2018, 08:55 AM   #11
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
It could be as a safety relay to kill all power when activated, when the E-Stop relay shuts of it has a NC contact that would then power this contactor, which would interrupt all power.
Sort of like the N.O. solenoid valve I put on the water meter at my house - if my alarm PLC detects a flood in the basement, or I activate it by the HMI, powering the SOL on shuts off the water to the house. That way I don't have to keep the valve powered on constantly, only when I want to shut off the water.
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Confused on wiring HoldenC LIVE PLC Questions And Answers 2 July 19th, 2018 05:02 PM
Confused by DINT tag program method. Need help. Dera bsee LIVE PLC Questions And Answers 2 February 1st, 2017 02:53 PM
Still kind of confused jaywillnot LIVE PLC Questions And Answers 7 November 23rd, 2015 05:06 PM
Confused about OTL jgauthier LIVE PLC Questions And Answers 15 September 2nd, 2013 12:08 PM
chemical calibration - confused irondesk40 LIVE PLC Questions And Answers 10 July 15th, 2008 04:17 PM
