Help connecting Masterdrive and PLC S7-315 via profibus
tglaria
Feb 2008
Concepcion
I don't get it.
I belive i'm configuring correctly the PLC to power ON/OFF and control the speed set point of the Masterdrive yet I get an error F082 no matter what I do.
Using Simatic Manager I loaded the 315-2DP PLC, added a profibus network, added the Masterdrive communication board, configured PPO 2 protocol.
On the masterdrive I configured the parameters so it starts from the first word of PZD and the setpoint is changed through the second word.
After programming a little bit the PLC, just power up everything.
The PLC sends the start signal to the MasterDrive, it starts, and I can change the setpoint, but only lasts like 5 seconds, then the drive stops showing F082 an the "SF" light of the PLC starts blinking.
Anyone has been through a similar problem?
Check the diagnostic buffer in the plc. F082 means missing telegram and its sounds like drive noise interfering with Profibus.
drive noise interfering with profibus?
is that posible in a (very) low power drive?
I'll check the diagnostics buffer and post it as soon as I can.
Hello all, hope your week is going well. I am currently working on debugging a Micro850 with Category number 2080-LC50-24QWB. When I connect...
2,349
Hi all Has anyone connected a baumer verisens vision to a tia I have set up the gsd file and have added the verisens to the network On setting...
3,077
Dear all, In a previous post I asked if someone had the software for an old Taian TP02. We used to sell our bandsaw machines with these PLCs a...
2,774
Hello all. I have to connect to a Siemens S7-200 CPU 224-XP using a serial connection with DB9 to USB converter. The converter is connected and...
3,438
Hello, I have some EVAP units that use an an OPTO 22 SNAP-PAC-EB2 Brain to control I/O. I downloaded the latest basic software package from OPTO...
1,702
