Help. My oc211 isnt work with cj2m cpu35
Hanifbenet
Oct 2018
Tangerang
Hi ihave plc cj2m cpu35 with module input id232 and output oc 211
When i try my program with cx programer. The input in the program is work and green line to go to the coil. But the center on the coil not green (grey). Input module led is on but led from oc 211 is off.
When i force it is work and led oc211 is on it work and it became like it supposed to be normally onn cx programer.what the problem. Thanks
Couple of things to check.
Do a compare of the plc code and your CX-Programmer program.
From the PLC pull down go to Transfer, then Compare.
Are there any Interlock (IL) or Jump (JMP) instructions in your program?
Mr gt. I hve tried to make a new simple program with 1 input and 1 output and upload to plc cpu 35 but even that dosnt work. And i tried with a different plc is cj2m cpu12. And my program work. If i use cpu35 on the cx programmers in my program line will be green but the coil (internal relay or basic relay) is not full green (the circle line is green but on the center circle is gray) It is different from using a CPU 12, the green light on the coil will be full on the circle coil in cx programmer
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
75
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
100
331
Hi all I need help on this As in my project used Schneider TM241 controller. Now I want to communicate Elite energy meter with controller by...
151
